Status
Not open for further replies.
1 - 2 of 2 Posts
Been gone and completely out of touch over the last three months...
Have any of the recent software upgrades fixed the 4:3 non-squeezed issues? I know the Toshiba unit for DirecTV has this taken care of, but was waiting for Dish's unit to fix as well...
Thanks in advance.
With the software update prior to the last one out 751, you are able to choose with or without vertical compression. It depends how old your set is though. Does your set do the vertical compression? If not them you can have the receiver do it and you will be able receive the correct ratio instead of everything being in the squeeze mode and everything looking tall and skinny.
1 - 2 of 2 Posts
Status
