Status
Not open for further replies.
1 - 2 of 2 Posts
Is it possible to get HD channels from ATT's local cable channels using the Dish 6000? Can I just stick the coax into the 8VSB module, and set the dish to 'cable' mode and get all the HD channels? I am in Chicago by the way; does ATT broadcast all the local channels in HD?
See my response to your question about WBBM-DT on cable in Local HDTV Info & Reception. AT&T/Comcast does not carry any of the Chicago UHF digitals in 8vsb, but you should be able to receive all of them OTA from Sears Tower with your Silver Sensor with your receiver set to Antenna mode.
1 - 2 of 2 Posts
Status
