I don't think Input1 15-pin RGB on the G11 will take 1080i/720P. If you aren't using an anamorphic lens I'd just go YPrPb into the G11 for now. Using the RGB out of the 6000, you could also use a 15-pin to 5-BNC breakout to go into the G11 on Input2.
Tom
Tom
