Status
Not open for further replies.
1 - 4 of 4 Posts
Mine did the same thing for a while, then went away. The only problem I was having was when you hit recall or switch from sd to hd, it would go to Ch. 580. this went away as well. I don't know, strange.
I have a Dish 6000 and when doing the dianostic check it says it has a vram failure. What does this mean and what is the fix? I would appriciate the help.
Thomas DiCecco
1 - 4 of 4 Posts
Status
