Status
Not open for further replies.
1 - 2 of 2 Posts
I have both a Dish 6000 HD and Ultimate PVR boxes. My Dish remote turns on both the 6000 and Ultimate box. I am using a Sony RM-VL1000 remote and would like to find a discrete code for the 6000 that does not also turn on the Ultimate box. I have tried a number of different codes with no success. Can anyone help or tell me where I might go to find this code?
Pat,
If you already have the discrete IR codes (i.e. downloaded from Internet) for the 6000, keep in mind that they were disabled with software version 778. They are re-enabled with version 780, which is being sent out to 6000s this week over satellite.
If you still have 778 on your 6000, you'll have to wait until you are updated to 780 to use the discrete IR codes.
1 - 2 of 2 Posts
Status
