Is anyone else using a Dish Network 622 HD DVR with a CRT projector? If so, which transcoder are you using? Are you having any problems with Horizontal centering.
I use am using a Moome external transcoder to convert the Component signal to RGBHV. I have to run the RGBHV signal through an Extron 202xi to shift the picture to the right so that it is on screen. All of my other RGBHV inputs behave normally. At this point I suspect the problem has something to do with the 622 but am unsure how to measure.
How do I look at a Component signal and determine where the horizontal position is?
Same question for RGBHV. What should a normal versus shifted signal look like?
The Extron 202xi shifts the picture back but since it requires the horizontal positioning control to be rotated all the way in one direction to accomplish this, I also get some slight double imaging in the bottom of the picture.
..Doyle
..Doyle
