Status
Not open for further replies.
1 - 7 of 7 Posts
· Registered
Originally posted by cgott42
Will the Dish Network 811 HDTV receiver (or any of their other models) support the DVI connection?
thanks
Its not DVI that you need, its Firewire. For soom reason, Dish decided not to put firewire on the 811. When the anouced the 811 back in the spring, it was to have a Firewire connection.
I say no firewire, NO SELL!
· Registered
Discussion Starter · #3 ·
I'm not looking to record it (though that would be nice) just wanting to connect it to the DVI in port on the projector. so I wanted to know which satellite receiver does that.
· Registered
The answer to your question is yes, the 811 will feature a DVI-D output.
· Registered
DAMN! I just bought a JVC 30K with hopes of using it on the 811.
· Registered
Another forum just posted the 811 spec sheet right here .
1 - 7 of 7 Posts
Status
