By playing around with the Fine Tuning settings I was able to get the Blaster to work. The recommended settings are
IR Code 0775
Fine tune settings:
Min # of digits = 3
SEND ENTER = YES
Inter-Action Delay = 0200
Response Delay = 0000
Pre-Command Delay = 0000
Inter-Command Delay = 0400
I found that I had to increase the Response Delay to 0500 to avoid having the No Video Signal Detected screen be the end state. With the increase, I still initially get the No Video message, but then the signal comes through after a pause.
Now all I'm left with is an occasional message from the Dish 301 receiver saying that I'm not subscribed to the channel, when in fact I am. This can happen from one Tune this Channel based change to another, i.e. over ten seconds, so it's not related to Dish downloading the program guide. Is there a setting on the Replay, or the 301, to address this? Thanks.
IR Code 0775
Fine tune settings:
Min # of digits = 3
SEND ENTER = YES
