Hello,
What is the format of the Analog HD signal coming out of the
622 or the 722 receiver on the component cables? Or does
anyone knwo who makes the units?
Would it be:
NTSC
PAL
HD 1080 Psf 23.976
HD 1080 Psf 24
HD 1080 Psf 25
HD 1080i 50
HD 1080i 659.94
HD 720p 50
HD 720p 59.94
HD 720p 60
Is the compression of the stream?
Uncompressed 8-bit YUV
Uncompressed 10-bit YUV
Uncompressed 10-bit RGB
Uncompressed Motion JPEG
Cheers'
Dave Cason
Would it be:
NTSC
PAL
HD 1080 Psf 23.976
HD 1080 Psf 24
HD 1080 Psf 25
HD 1080i 50
HD 1080i 659.94
HD 720p 50
HD 720p 59.94
HD 720p 60
Cheers'
Dave Cason
