Status
Not open for further replies.
1 - 7 of 7 Posts
Ok, I am not sure if I am in the correct forum or not, but I am going to shoot! I am sure someone will let me know! :)
Long story short, but I was a longtime Dish customer (8 years), disconnected, moved around town, and now am wanting to connect again. I had my own dish but got rid of it as I "thought" I was going to stay with Time Warner, but ther service is terrible, so now I am stuck.
I have had DTV over to my apartment and the tech said that he needed a direct line of sight, due south, and since there was an overhang, he couldn't install it.
Next option, switch to Dish; Dish tech came over and told me that the line of sight was good, but since there were new apartment guidelines due to a recent lawsuit, he couldn't install it. Now I don't have any problems installing these things as original install in Denver was done by myself, and another one in KC as well.
The problem lies in that I don't have my equipment anymore - dish and receiver!! When I disconnected, Dish, with their infinite wisdom, told me to return the receivers - one I owned, the other, they did (Dish 811).
I need a new "Dish 500" dish and a new receiver, but can't get this if I call Dish due to the above explanation.
Bill "Stumped!"
Look up OTARD online, there hasn't been any recent lawsuits that impact it. It's the FCC act that allows you to install a dish in certain areas around your apartment and has been in place since 96.
Discussion Starter · #3 ·
Thanks for the reply! :)
The tech said the lawsuit was about an apartment catching fire due to lightning and an improper ground.
I am familiar with the act in 1996. My apartment in Denver told me to take down my dish, and I told them where to go as I slapped down the entire printed FCC act!! Needless to say, I didn't get any complaints from them!
But I still don't know about my issue with equipment!
That brings me to the next concern...grounding. I have installed it and not grounded it and had no problems. Any ideas?
Bill
Try Ebay !
Get Receiver & Dish, install it and call up Dishnetwork and Activate it. Just make sure that the Receiver you get off Ebay is Free & Clear of any Balance (and not a Leased one) .
Discussion Starter · #5 ·
I thought of that and will probably go that route.
With the new 942, do I need two dishes or can I go with the Dish 1000 antenna? Or should I not use this one and use the old style?
Bill
1 - 7 of 7 Posts
Status
