Status
Not open for further replies.
1 - 5 of 5 Posts
I just installed the ota module in my dish 6000. I have it hooked up to a 100" yagi I bought from Radio Shack. After installation, I scanned the digital stations in Denver, and got the 3 that are available at a minimum of 70%. I then moved my entertainment center back and then all of the sudden, I can't pick up any channels, 0%. I rechecked all of my connections, they are tight. Any suggestions?
Jason
Discussion Starter · #3 ·
has anybody had this happen to them before? I'm thinking I might have a bad ota adapter.
Jason
Are you getting analog channels? Are they clear? Are they being transmitted from the same location? If your antenna is uni-directional, it may need fine adjusting.
-- Dan Farris
I don't have the same hardware but I would pull the plug on the 6000 and remove and reseat the OTA module. Plug the receiver back in and rescan.
Rick
RJW
1 - 5 of 5 Posts
Status
