Status
Not open for further replies.
1 - 3 of 3 Posts
Set up my Dish5000 w HDmod this weekend and I am feeding the output to the Hipix Card. Everything works great. When I add the Silver Sensor output to the rear of the modulator, the Hipix does not pick up the OTA channels when I autoscan. Is there a trick to getting the OTA 's to work with the 8VSB signal from the modulator? If I feed the Silver Sensor into the Hipix by itself, it is fine.
Ed Betty
You have to add a local HDTV channel to your 5000. It doesn't matter what channel it is.
Then you tune to that channel and the demodulator card will pass your OTA source to your HiPix.
You'll come into the HiPix as channel 3 or 4, depending on your 5000 setup menu option for HDTV--not the regular satellite choice.
Stan Z
1 - 3 of 3 Posts
Status
