Status
Not open for further replies.
1 - 2 of 2 Posts
I currently have a dish 500 with two receivers. I am using an htpc with hipix card for locals, but would like to add the dish network channels.
My question is, where can I get the recevier (6000?) for cheap and what else do I need? I called an installer and he said that it would be $669 for him to install the other dish and receiver, but can I do it myself cheaper?
and, is all of this for 1 ppv and 1 showtime? I live in SLC and there aren't many HDTV channels available.
jeffrey
You can by the dish 6000 for $450 from various online sources. The dish 300 will be around $70 and you can install it yourself if it is not a complicated install. Try dishdepot.com, dishusa.com, amsat.com
Eram
1 - 2 of 2 Posts
Status
