1 - 6 of 6 Posts
Newegg today has SAPPHIRE 100293DP Radeon HD 5570 1GB 128-bit DDR3 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Low Profile Ready Video Card w/ Eyefinity
Was: $79.99. Now: $69.99 with free Shipping
$20 off w/ promo code VGADEC003, ends 12/3
LINK
I want to replace the old HD 4550 of my HTPC by this card which has a DisplayPort and DVI port (not HDMI).
Most of my movies are BR and BR rip. Any body can confirm HD audio can be passed thru DisplayPort or DVI port with a HDMI adapter to my Onkyo receiver? Thanks for your prompt reply.
ATI has their own special DVI/HDMI adapter that either uses unused DVI pins or shares pins to pass HD audio. You must use this adapter if you want HD audio as a typical DVI/HDMI adapter does not have the same setup.
As for DisplayPort I do not believe it can pass audio. But I have very little knowledge of that connector and it's capabilities.
Well, the ATI adapter will end up costing you at least $10-$15, unless you can get Sapphire to send you one for free.
So adding on the cost of the adapter to the cost of the card and I would say its not worth it.
Just get a card with HDMI out.
Just last week Newegg had a fantastic deal on a 5550 for $10.
Come close to Christmas time and something like that will come up again; if not for $10, then for $25.
1 - 6 of 6 Posts
