1 - 5 of 5 Posts
Trying to find the best placement for my 5.1 surrounds. I wanted to mount both the LR and RR speakers on the side walls about 2ft above the listening position on couch. I am concered about the distance between the speakers. I was thinking I could tweek the reciever settings to make it work.
my set up was almost the same (move the couch closer to the right)
i set the distance on my hd-dvd player. then i listened to my speaker test tone. i just increased the db of the furthest one to make up the distance.
you could go to radio shack and buy a sound level meter, bring it home, and set them to match exact.
then bring back the meter..
Apparently ethics is not a word in your vocabulary.
When you calibrate your receiver for dB levels and delay (distance) you will be just fine.
1 - 5 of 5 Posts
