Status
Not open for further replies.
1 - 2 of 2 Posts
Because it has proven difficult to find side by side specs for these projectors, can anyone tell me the significant differences between these two projectors?
Also, any comments on the qualities that might make one better than the other would be appreciated.
9 PG+
94 Khz scan rate
7 1/2" tubes
800 lumens
XG 75
75 Khz scan rate
1200 lumens
8" tubes
(I think those are right..)
Similar pix, but given the same price and hours, I'd take the XG.
The green tubes wear faster than the blues on both of these in my experience, so make sure you check that out.
NEC and VDC are out of new greens for the PG series for a while FYI.
Curt
1 - 2 of 2 Posts
Status
