Status
Not open for further replies.
1 - 2 of 2 Posts
I got the box installed and all of the wires run, but now I need to terminate everything in the box. What would your recommend that wont make me go broke???
I have the following:
9 cat5e data/phone drops
5 rg6 cable drops
The box that I installed is the Leviton 280 with a 2" extension.
What would be my best bet for patch panel??? I dont have a home phone so all the drops will be data right now, but if we decide to get a home phone I want to be able to pick and choose.
Any recommendations???
Ben
5 rg6 cable drops
Ben
Well, there's lots of different ways to go, but probably the easiest is this:
http://www.levitonvoicedata.com/cata...ildPageID=2503
With an additional:
http://www.levitonvoicedata.com/cata...ildPageID=2515
To get you to 12 ports.
If you want to use it as a data port, simply add a patch cord to your router/switch/hub. If you want to use it as a phone port, you add a small jumper between the two modules, and the incoming telco line goes on the top punchdown of the phone module.
You can terminate the 5 RG6 drops on the splitter, assuming you are using them for standard RF cable. If you have something else in mind, then I recommend this instead:
http://www.levitonhelpdesk.com/catalog/
It is a multimedia adapter plate that you stick some F-type coax connectors into (see lower catalog link). Then you just patch from that to whatever you need with coax cables.
Robert
1 - 2 of 2 Posts
Status
