Originally posted by reaper
I've compared a friend's (gatrswmr) Diva 6.1s/C3 to my Paradigm Reference Studio 40s/CC. He has the 3802 and I have the 3801. So, it was a pretty similar comparison. The biggest difference we noticed was a brighter (crisper) tweetwer on the Diva Speakers in general. I haven't listened to either the 2.1 or the 20s. But I'd be willing to bet that trend would continue to those incarnations as well.
In response to your question about the increase in price/performace... that's a personal preferance. I'd respond yes, get the Paradigms because I like the sound of the Paradigm tweeters. I think they are more natural and lifelike. But gatrswmr would probably say, no get the Divas because he prefers the bright sound of the Diva tweeter (and that rosewood finish).
Don't know if that helped...
reaper |
Hi dn38416 and reaper,
Both of these speakers are great products for the money. Many have done comparisons directly with the Diva vs. Paradigm reference, and if you get a few minutes, dn38416, you should post this exact same inquiry on the big Diva thread here. You'll reach far more people this way, and will most likely benefit from the HUGE pool of collective knowledge these threads can offer. I know for a fact that many have done this exact comparison, and several people have even taken their Diva's into their local HiFi dealers to do blind A/B comparisons.
Regarding your comments, reaper, do you know how many hours the Diva 6.1/C3 had on them when this comparison was done? The only reason I ask is because in all accounts where I've heard these speakers discussed, the findings are reversed completely. In most cases, and in my experience, the Paradigm series of speakers is actually quite a bit brighter than the Diva's. This is due to the use of a smaller 25mm PAL (pure aluminum dome) tweeter as opposed to the Diva's 28mm German silk dome. By nature of their design, silk dome tweeters tend to be a bit more relaxed than metal domes, and begin an ever-so-slight inherent roll-off right after about 10 kHz. In the Diva's case, this tweeter is about 3 dB down at 20 kHz, whereas the Paradigm is about 2 dB down at 20 kHz. Take a look at the TN28 Diva tweeter specs here:
Diva Tweeter Link
However, this tweeter does take a pretty serious break-in period before you'll realize this performance. Out of the box, the Diva tweeter can sound somewhat "bright" and even "harsh" at times. But after about 70-100 hours of playing time, the high frequencies become much more extended and smooth, setting up a wide and relaxed soundstage usually 2-4 ft behind the speakers. If you did this test before the Diva speakers had been given adequate break-in, this may explain your findings.
Nonetheless, neither of these qualities is "better" than the other...in the end, it all boils down to what sounds best to YOUR ears. If you like the sound of a metal tweeter, the Paradigm may be your best choice. However, if you do significant 2-channel listening, and like the sound of a soft dome tweeter, you may consider a Diva audition. The best way to answer your question would obviously be to hear the Diva yourself. Take a look at the following site set up by a proud Diva owner:
www.audioenvy.com. Here you can actually arrange an audition of the Diva speakers and learn exactly what to expect from these speakers!
Thanks again for the post...please let me know if I can be of any further assistance!
Kindest regards,
