1 - 20 of 307 Posts
Discussion Starter #1
EDIT
12-19-08
There has been a new development.
There is now a self-extracting rar of the ISO that clocks in at only 202 MB!
Say thank you to jarrod1937 . He has offered to host the file own his own bandwidth for a time.
My connection is no good right now (crappy line noise), but if someone would be kind enough to grab the rar and start a new torrent that would be great. Here is a link to jarrod1937's file: http://jarrodchristman.com/AudioTestDVDv2.exe
-The link to the old (803 MB) torrent is right here .
Thank you swithey, 80211mdr, J. L., and blown65 for the help in getting this out there.
EDIT: The FTP option is no longer available, sorry. You can go to http://www.imgburn.com/index.php?act=download to download the free ImgBurn program to burn the iso for you though. Please skip on down to the next section, unless you just want to learn a little about FTP file transfers.
FTP-How-To (the free way)
First PM Zip(AUS) or Nada(USA), and ask to gain access to the ftp site location and pass codes. Remember to thank them.
Please keep the username and password he gives you to yourself. It is a free service to you and that is the only rule. Please remember it.
Next download this program FileZilla Pick the latest .exe
This is what it looks like.
All you have to do is enter the address, username, and password you got from swithey and then hit Quickconnect.
Now the Local Site on the left is where on your computer you want the files saved to. The Remote Site is the FTP server.
First go into the ImgBurn folder to get a program (SetupImgBurn_2.1.0.0.exe)to burn the DVD .iso Click the ".." file to go back out a level, to get back to the main menu. You should now be able to move around and download whatever you choose to from the site.
Once you are ready to burn the .iso, start the ImgBurn program
It is pretty straight forward, and you should have no problems. In the Source box, click the folder icon with the magnifying glass and find the .iso you want to burn. Now just place a DVD in your burner, and click the big disk picture that lights up. That's it, you're done.
The LFE calibration is for a sub good to at least 100hz. If your sub naturally rolls-off earlier than that, you use a lower LFE xover point, you don't have LFE and sub xover points on your AVR, or you don't use it's xover bypass use the 2.0 Sub cal. Trust me.
Discussion Starter #3
A little more...
I'm looking at Dolby Digital 448 Kbps, 48,000 Hz, 5.1 Surround. I don't have any DTS encoders.
Now the question is where do you want the LFE lowpass? 180, 120, 116(DTS), or 80hz? There is also a no lowpass option. I'm thinking 120hz, but it lists it as Pro/film with 80hz as consumer/DVD.
One other thing, are 5 sec sine wave tones good? Do you want them shorter or longer?
They can be on a loop with 3 sec of silence, or just repeat 3 or 4 times and then end.
What else should be on here?
I'm curious as to why you'd have the tones at -20db and the sweeps at -10db. Why not have them both at 0 or -1db? Also test tones around 10sec would be great!
One of the disks I have has sine waves at 3 different levels, 0, -5 and -10db for 30secs each. Pink noise is 60secs and it has a sweep from 1-180hz where each second equals the frequency...It's stereo though since it's an old CD and not a DVD.
Cool Soho! I think the LFE channel with no lowpass would be the most valuable. I think DD movies use a 120 Hz lowpass when recording but DVD-A and SACD don't have any standards and may not use any filter. For testing purposes, it would be good to see what your gear does with a full-range signal on the LFE channel. Most cut it off above the XO frequency you set but you never know what the various equipment mfrs are going to do.
Discussion Starter #7
I started this as a bass management test disk only. The thought was to have all tones and PN play back at 85db with sweeps at 95db for improved lowend audibility.
10sec tones it is. Now should they loop with a 3sec pause, or just play once?
No lowpass it is.
I can do things like this, but I am worried about the destuction it will cause.
Discussion Starter #9
This is what I have done so far, and are available for all channels:
Sine waves- 5sec and 10sec tones with a 3sec pause. this repeats 4 times.
1-20hz in 1 hz increments 25-120hz in 5 hz increments -20db
Pink Noise- 30sec tones looped In 300-2000hz, 20-80hz, and 10-20,000hz bands -20db
Sweeps- In 10sec and 30sec-Both Forward and Reverse Individual Sweeps
10-80hz, 10-200hz, 10-20,000hz, 20-200hz, 20-20,000hz, 30-300hz -10db
I can do multi channel tests and phase inversions. What kind of stuff like that do you guys want to see?
I am going to add some 0db content for those who crave it.
Sweeps- In 10sec and 30sec Forward and Reverse Individual Sweeps
Pink noise: Mains-center, mains-suround, surround-rear, mains-rear, mains-LFE
In phase/ out of phase: Mains-center, mains-suround, surround-rear, mains-rear, mains-LFE
Discussion Starter #11
crackyflipside, the full calibration suite with extras. No problem.
It'd be cool if you could include Brittany Murphy somehow. And Pink. Yeah, that'd be a disc to have.
Discussion Starter #13
Jack Gilvey, Easter Eggs. No problem.
Discussion Starter #14
This menu is getting to be a nightmare.
It's going to take a month at this rate.
I think I'm going to drop the 5 second tones, and only have the 10sec ones. Any objections? That should free up a week or so.
I found another sine generator for sub 10hz sweeps, but it puts an edge on the wave. I don't like it. I'll leave one on there though.
Anyone have any copyright free (bass heavy) music or sound effects that can be added for giggles. I have tons of space to waste. This DVD could fit on a CD.
Discussion Starter #15
Here is the menu system so far. This is as deep as the levels on the DVD go. The norm seems to be about 5, this is 7. The wave is playing in the last pic, at -20db. The 5.1 section will be similar.
If you need help, I have a program that can generate ANY audio you could imagine up to
192000 sample rate (stereo) 32-bit
It can also generate Pink noise, and two others I have never heard of (white noise and brown noise)
Also generate any pefect sine waves or sweeps you can imagine, but just in 2-channel.
Discussion Starter #17
The one I am using can only do sweeps to 10hz. I have tried a few different programs that could dive below 10hz, but none of them created a perfect sine wave. I'm trying to stay with true sine waves, with out the harshness you get from the car audio forum tones. A 48000/16or 24bit/mono sweep from 1hz to 80hz over a 30sec period would be great.
Pink, white, and brown noise I have covered. White noise is random with a flat spectral density, pink has a 3db/octave roll off as frequency increases, and brown rolls off at 6db/octave. White noise is that crap noise an old CRT tv made when it was showing "snow."
Discussion Starter #18
cracky I forgot to say, "Thank you for the offer and help.
Sure thing, what level do you want it recorded at -20db or -30???
Discussion Starter #20
Anywhere between -20db and -5db. I'll adjust it in the final mix to -10db and 0db. Just make it a strong signal with no clipping, and it will do fine. Thanks.
The part that is taking up all my time is doing the menu layout. This is going to be menu driven and there is going to be around 6245 screens at last count, and I have already cut 4000 pages out for the v1.0 release.
I am going for easy of use, not design. I don't know who came up with the DVD menu system, but it sucks.
I'm almost through with the 2.0 section. Once that section it is done I'll start some non-computer testing. Then when the bugs are gone I'll finnish the 5.1 section and distribute. The only problem is the wife is already starting to complain about my time on the computer, so I'm going to have to turn it down a notch.
1 - 20 of 307 Posts
