Status
Not open for further replies.
61 - 80 of 127 Posts
Originally posted by BasementBob
Toeside:
DE has made some negative comments about broadband absorbtion, e.g.
http://archive.avsforum.com/avs-vb/s...60#post2416260
and I note that aiming a surround at a corner trap isn't a great idea, but that said, I think that if you have no other treatment in a room, and have measureable modal problems, then DIY corner traps are worth a go for combining cheap and effective.
There's a couple of examples of absorbers at the end of this page
http://www.bobgolds.com/AbsorptionCoefficients.htm
the most relevant are probably
http://www.bobgolds.com/TrapHarder/home.htm (superchunk corner)
and
http://forum.studiotips.com/viewtopic.php?t=534 (4" thick at corner)
For the superchunk style, there are three cut patterns that effeciently use all of a 2'x4' sheet of rigid fiberglass, depending on the size of the diagonal you want.
For 24" and 34" please see http://forum.studiotips.com/viewtopic.php?t=535
For the 48" cut pattern http://www.bobgolds.com/CornerTrapCut.GIF (SuperDuperChunk)
Thanks for the links, Bob. I had something a little different in mind. More like what's pictured here at Kinetics . That URL is a flash page, so click on "Acoustical Kit" and look at the wedges in the corners.
I don't want treatments are are super intrusive in the room. No offense to Ethan, but his traps just wouldn't go over well in my room. Tubes could probably be blended in a little better, but my better half still didn't like that idea. These wedges are probably the least intrusive, so they'd be my best bet as far as WAF goes.
I'll read up on the link to DE's posts....
Scale back a LITTLE!? Tha's great for a studio - not so good for a HT.
I showed my wife pictures of the Kinetics treatments. She's approved the corner wedges (DIY, not actual Kinetics) should we need them. She's still not thrilled with other wall treatment ideas, but I told her I really want to address first reflection points at a mininum.
Hopefully I'll be read to take these measurements in a few weeks.
There are several things you can do to increase the visual appeal of the treatments. You can cut them into 2x2 squares and hang them as diamonds - using different colors if you want for interest. You can use a patterned material. If she's a good seamstress, she can sew a pattern from different appropriate materials for the covering, etc.
Just don't get hung up that they have to be these monolithic 2'x4' monotone rectangles hung on the wall.
Thanks BP for the reminder.
She is a pretty good seemstress, so that'll be something she can work on. We still need to agree on a color scheme. So far, the only thing that's been agreed on is the black GOM on the screen wall.
Esthetically, the best thing you can do with room treatments is to hide them behind acoustically transparent fabric. Commercial movie houses use pleated fabric on the walls. Home theaters typically use tightly-stretched Guilford fabric.
I'm sure there are other creative solutions for those who can think outside the home-theater-in-a-box. ;)
- Terry
- Terry
I know most home theatres here have GOM walls with Linacoustic or an equivalent from the floor to ear level, then poly batting above that. I had a hard time getting my wife's buyin for a fabric front false wall, and it's already been determined that fabric walls all the way around is a no-go. I'll be one of those people thinking ouside the "home-theater-in-a-box". :)
Hi Toe,
Yeah, you've got your work cut out for you. Usually the only thing most wives agree on in a home theater is that all the walls SHOULD have fabric on them. ;)
Larry
Ok, I had some time this weekend, so I decided to create some bass traps. I did a very simple square using corner piece edging from HD ($1.89/ft). I already had the insulation (same as OC 705). I still need to wrap the top half with 2mil plastic (my mains are bi-polar, and I don't want to absorb the rear-firing mids/highs), and then wrap them in some black GOM I have. You also may notice I have them about 3" off the ground....that's because I have speaker terminals on the front walls close to the corners and wanted to be able to run wires under the bass traps.
This first pic is the simple skeleton of the trap without insulation.
-Jason
Here is a picture of the completed trap. It's roughly 12"x12"x36"
BTW....there's 4 (2'x4') sheets of insulation per trap. I guess I should also note....that low and behold....they actaully DO make a difference....and in my case....a pretty big difference in cleaning up my low end. I guess in laymans terms....my bass sounds/feels much tighter.
Not that I didn't respect him before....but I just gained more respect for Ethan
jasplat88:
I like it !
I like it jas. Toe, cover that in some nice cloth, stain and seal the top plate to match the furniture, put a nice plant on top of it and poof - instant WAF.
Very good idea. Nice design, jasplat88.
I have a couple ideas based on this, let me know what you think:
1) build two of them and use them as stands for my front speakers; JBL E30 bookselves
2) using full 2x4 sheets (or slighly smaller) make an ottoman
I don't know if placing my L&R speakers on one of these traps is a good idea. Nor do I know if placing an ottoman-shaped version in front of the front row would be a good idea.
As far as just building what jasplat88 has, I could easily put them in the front coners (they'll be behind my false wall), and in the rear right corner, but the rear left corner will have my A/V rack. There's only about 5" between the rear wall and the edge of my rack.
I wouldn't use them for stands for a couple reasons.
1. They're not sturdy enough to make good speaker stands which should be very rigid.
2. If you're limited on location (you are) and need to maximize more broadband bass absorbtion (you do) the corners are the best place for them - not where your main speakers are.
If you can get 3 of these in the room, that would help out significantly as your space is pretty good sized. Or, since 2 will be behind the false wall and you don't care what they look like, just get some 3-4" and straddle the corner from floor to ceiling. Then build just one like this and put it in the back.
Here's a silly question: could you clad a colum trap like that with a relatively thin (say 3/8" or thinner) wood panel, or would that be too reflective for the acoustical benefits that we're trying to achieve?
I'm wanting to incorporate a similar type of trap material into my rear corner columns and I'm just trying to decide what the best covering material would be. I could easily go with the same GOM fabric as the rest of my walls, but I think stained wood would look much better.
Hi,
A point to remember is that we're all not trying to achieve same thing because we don't have the same acoustic situation to deal with.
For example, you say that the rest of your walls will have Guilford of Maine fabric on them. This implies to me that you intend to acoustically treat your entire room. If so, the reverberation time for your high and medium frequencies could be sufficiently low with the wall treatments. Jason's bass trap without a reflective covering appears to be a simple broadband absorber. Therefore, without a reflective cover it will absorb a whole spectrum of frequencies. In a room whose walls are already treated this may make the room too dead in the higher to mid frequencies.
I would be interested in hearing what the experts have to say in response to your question, but before they can answer it intelligently they have to know what type of absorption the user needs. In other words, putting a reflective covering on it may be a good thing for a user who is only interested in low bass trapping.
Larry
Thanks for the reply, Larry.
You bring up a good point, as I was curious as to how a wood cladding around a bass trap like this would affect the bass absorption in a room with what seems to be the more common Acoustimat (bottom) / poly batting (top) covered with GOM. In my case, my room will be fairly small (roughly 15 X 12), so I don't know whether the wall treatment alone would be a little too absorbent of mids and highs (in which case I could benefit from the wood cladding) or I would need a bit more broadband absorbtion.
Status
