Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
I have seen monkeyman and breakstuffs' diy set up and love the idea. However, I only have 1 centered screw placement for ceiling mount (proxima dx3)
Anyone with the same setup who has accomplished the feat please point me in the right direction. Or if there is a reasonable place to purchase one (preferably in Canada, avoid the duty and huge shipping), please let me know.
thanks to all for their help
that's rather odd. Seems a bit insecure.
But, you could make a plate that the single screw attaches to the PJ. The plate would have 3 or 4 holes for the leveling screws and would work just like monkeyman's.
I used monkeyman's idea and adapted it to an HS10 which has 3 screws (not 4 like his PJ). One in the font and 2 in the back. works like a charm and adjusts really easily. I used plywood instead of plexiglass.
1 - 2 of 2 Posts
Status
