Status
Not open for further replies.
1 - 2 of 2 Posts
Helllo,
I need to run hi res video from my computer to my projecter. My projecter is on the floor, and I have conduit running in the cement. It is only 1" in diameter, so a prebuilt cable would be impossible to run. Does anybody know where I might information about making one, or maybe another option? I would need about 25'
Thank You
-Bryan
I assume you want VGA output to VGA input on the pj. So, you can call these folks - they are quite helpful and have been known to send you the ordered cable, with the connector complete on one end and just the pins installed on the other (rest of parts in a bag - easy to put together). Call them and see if they are still being helpful.
http://www.bettercables.com/1met328feetv.html
VGA connectors are difficult to install - but here is help on other type of cables.
http://www.bus.ucf.edu/cwhite/theater/diycable.htm
1 - 2 of 2 Posts
Status
