1 - 20 of 21 Posts
I want to control my bluray-HD.DVD-AVR-Projector all which have serial ports. I have actually done this individually, but want to do more control but have no idea what is available except the Extron Ip link stuff.
What is available that is non-pro installed? What do you guys use? I have the software already which will send the codes.
IS there something inexpensive?
Clay
Discussion Starter · #3 ·
Originally Posted by petern /forum/post/19599809
Global Cache GC-100 and iTach products. What software are you planning to use?
Currently I use Home Control Assistant which supports UPB very well.
Charmed Quark and Homeseer are on the radar.
Clay
Elve might be another platform to consider.
Discussion Starter · #5 ·
Based on what I'm reading these only have 2 serial ports. I need 3 at an absolute minimum, and would like 5 or 6 available. Maybe I need to stack them which would get cumbersome.
There website has sparse information, but the pricing is attractive.
Clay
I used a cheap 8 port serial board with an octopus cable I purchased from Newegg. I don't find the exact one, but it is similar to this one. I only paid $32 for it. You could also try Amazon.
http://www.newegg.com/Product/Produc...82E16815317013
The software is Elve which is available free during it's beta period, then will be $99 for the introductory period.
http://codecoretechnologies.com/content/MainPage.ashx
I haven't had a single misfire or glitch since putting this package together.
Deane
You could use a networked serial server. A Quatech brand has been discussed extensively in a couple cocoontech.com forum threads.
http://www.cocoontech.com/forums/ind...dpost&p=130220
Or if the controller is local, a Digi Edgeport expander might be useful.
I use a 2 port Edgeport USB-serial adapter on my rack PC to communicate with my Nuvo distributed audio system, and will be using it for RA2 programming.
Discussion Starter · #8 ·
Deane
That Elve software looks interesting, but the serial card won't work as my PC is about 30 feet and one floor away from my equipment rack.
Clay
Discussion Starter · #9 ·
If I had a rack mount PC I could add the octopus as mentioned by Deane, and I'd be set.
I may think about this as well.
I think serial control cables can be much, much longer than 30 feet.
Spend some time on the Elve forum, or search at cocoontech.com.
Discussion Starter · #11 ·
This is true. I have one now, but I don't want to run 5 or more though the floor or walls. This is why I was looking for a router/control box.
I think coccoontech is my new favorite forum!
Clay
So that it's clear, Elve and the serial card are separate items and one doesn't depend on the other. That just happens to be the software I am using.
You're right, it is interesting. Very robust and easy to learn to use.
Running 5-6 ethernet cables maybe the easiest, and cheapest.
Discussion Starter · #14 ·
Easiest and cheapest for sure. Not acceptable in this situation.
I assume you mean ethernet cable terminated in serial connectors. Which means technically I would only need 2 or 3 as they have 8 wires each. If you meant true ethernet I would only need 1 which is already there.
I am going to continue to look at serial routers.
Clay
Discussion Starter · #15 ·
Purchased two serial gateways/servers on ebay for 20 buck
Digi ts8 models.
Realport software.
will see how this works.
Another possibility is the Global Cache GC-100. It connects to your network, and provides several serial ports at a remote location. My son, living in another city, uses one to get serial connections on his HA three floors away from the server.
I don't have one, but wish I did. Those using it seem very happy with the results.
Discussion Starter · #17 ·
This was the direction I started in, but there's only two serial ports.
Digi ts8 models.
Realport software.
How did this work out for you? Just curious.
Discussion Starter · #19 ·
The two I bought first were dead. I bought a ts16 which works wonderfully.
It's as if the serial ports were directly connected! I love it.
Clay
Clay
Curious as to what kinds of devices you've got hooked up to this and what connection methods you're using. I too picked up a TS16 and have got it up and running, just not sure where to go next. Honestly haven't had time to play with it....
I'm looking to control an Extron matrix switch and a Nuvo audio system this way, with an iPad running the iRule remote app.
1 - 20 of 21 Posts
