I just bought myself a 55"x3yards RP screen that I now need to attach to the frame I built out of anodized conduits, much like in the following link:
http://outdoormoviescreen.blogspot.com/
Now since Id like the screen to remain closer to a 16x9 ratio than to a 2.35:1 ratio, I'd like to use a different way of attaching the screen to the frame than the one proposed.
Whichever method you can propose should allow for a quick setup (I'd like the screen to remain transportable/easy and quick to setup)
So far I tought about using grommets or sewing some band of tissue on the side to allow the tubing to fit in these band of tissue. Any positive/negative comments on these approach?
I did a few search but I guess I didnt used the good keywords
Benoit
Benoit
