Well, the better half doesn't really like all the audio equipment in the living room because it more or less takes up an entire wall. Right now I have my RTi12's surrounding a tv stand with tv and a component rack and a 12" infinity powered sub. She really hates the component rack and isn't a fan of the giant black speakers either as they stand out too much. I'll ignore the speakers for now but I was thinking I would integrated all the components into one stand under the tv and hopefully integrated the sub (I know it may not be an ideal placement). Reading through the entire Sub1/Sub2 thread got me thinking. Perhaps I could integrated a sub into the stand while leveraging many smaller drivers to give that over the top punch, just with a smaller floor-print. It might also have the benefit of creating clean, fast bass for my music. The pic below is kind of my thinking with the subs being opposed and on each end of the system to cancel vibration(and perhaps only 2 high instead of 3) giving between 8 and 12 drivers.
What limitations will I run into (damage to my components, etc)? Any driver suggestions that can take gobs and gobs of power, low distortion, and have a small footprint (thinking sub 1 size but better power handling)? I was looking at the TC sounds 10" driver on AE but I need to read up on how to model that and understand the volume required and need to understand how the dimensions of a sealed box impact sound. I'm on remote work assignment right now and can't measure my actual components but I need to fit:
RMB-1085
RB-1091 X 2
RSP-1068 (possibly something else so I can get DTS-HD MA etc)
PS3
Xbox 360
TV box
Pro Amps for subs
H15 power conditioner
Polk Center Channel (CSi5)
Mostly right now this is just a pipe dream but I want subs that are portable until I get into the next home... Where I'll build an IB in a dedicated theater. IB in this home would also be bad spreading too much DB's to the bedrooms.
RMB-1085
RB-1091 X 2
PS3
Xbox 360
TV box
Pro Amps for subs
