Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
No idea what that is. I'm completely new to this. I'm looking for my brother who has a very nice wood shop in his home and recently built a home theater in his basement.NU1000, 2 1262w's and a sheet of mdf. Should be right at $300.
Any other constraints or goals?
No, its DIY. Someone can post all the info you need so you can build it (sketchup model, cut list, and a simulation on how the sub will perform).No idea what that is. I'm completely new to this. I'm looking for my brother who has a very nice wood shop in his home and recently built a home theater in his basement.
Does that come with instructions, specs, blueprint and so forth?
No, it's DIY.No idea what that is. I'm completely new to this. I'm looking for my brother who has a very nice wood shop in his home and recently built a home theater in his basement.
Thanks. I like yours too.NU1000 is shorthand for the Behringer INuke NU1000 amplifier. The 1262w is a model of sub made by Infinity, arguably the best low budget 12" sub driver you can buy. and I'm pretty sure the mdf part is self explanatory.
As far as blueprint goes, if you tell us your goals we can design an enclosure to meet your needs. More specifically what are your size constraints and will this be used primarily for music, movies, or both. What size room will it be going on? The more details the better.
Nice Avatar btw!
Huge can be a lot different for different people...No constraints really except somewhere close to $300.
It's going in his home theater. Roughly 20x15x8 sealed room. Purpose built but no room treatments. 110" projector. 7.1.
Would be 90% movies/10% music.
He has a Klipsch RW12d right now that just doesn't have enough output. Like to get something that will provide a little thump but doesn't need to go super low.
Size is not an issue as long as its not huge.
Thanks for the links. Looks nice. I'll read through the thread and see what I can learn.No, it's DIY.
http://www.sweetwater.com/store/det...Dx9SELemsiPpEMiGNdyAXGBcfzRtihJgbxBoCuqXw_wcB
http://www.amazon.com/Infinity-Refe...qid=1426709701&sr=8-1&keywords=infinity+1262w
There are builds out there though. I'm sure someone has an example.
Here's one http://www.avsforum.com/forum/155-diy-speakers-subs/1917921-16-x-12-sealed-sub-cabinet.html
Something roughly 30x30x30 would be an easy fit. It's most likely going to go up front somewhere.Huge can be a lot different for different people...
Also, does he have room for 2 enclosures vs. 1 dual enclosure?
Good to know.30x30x30 is big enough for a dual driver ported enclosure using the 1262w. You'll also need a highpass filter so look into the inuke nu1000DSP but that already puts you over $300.
$200 for the amp and $130 for the two drivers. Plus wood, glue, and paint...
If it's going up front then I would say to build one long box that is short enough to fit under the screen and put the 2 1262's in a box tuned to ~20hz. If you can fit a large box you will be able to dig deeper a lot easier so that's an advantage to not having a size restraint.Something roughly 30x30x30 would be an easy fit. It's most likely going to go up front somewhere.
He won't go through the trouble of proper placement or eqing. I've already tried. He's not nearly as picky as many of us.
He has room for 2 but likely wouldn't go for the idea. Maybe if he put them both in front but that would kinda defeat the purpose. Rather just get him 1 with the most output possible. Doesn't need to be clean and articulate but, of course, not a boom box either.
lol Sounds like a monster. I like it!If it's going up front then I would say to build one long box that is short enough to fit under the screen and put the 2 1262's in a box tuned to ~20hz. If you can fit a large box you will be able to dig deeper a lot easier so that's an advantage to not having a size restraint.
I would shoot for ~10 cuft. net internal volume and a slot port 2.5" x 20" or so with a length around 25". This should keep port velocity under 16 m/s and with a hpf in place keep cone excursion in check with 650w. You should be able to hit ~112db's at 20hz with this setup, not too shabby for a pair of 12's, not including any room gain.
As MrKazador said, you will need the hpf so get the inuke 1000dsp. We know this goes a little over budget, but for the price no commercial offering can come remotely close.
Many thanks for the links.![]()
DCS450 $125
http://www.parts-express.com/dayton-audio-dcs450-4-18-classic-subwoofer-4-ohm--295-475
SPA250 $125
http://www.parts-express.com/dayton-audio-spa250-250-watt-subwoofer-plate-amplifier--300-803
5ea 3/4" 2'x4' handy panels $60
http://www.homedepot.com/p/Unbrande...34-in-x-23-75-in-x-47-75-in-1508112/202089064
10ea 1/2"x48" dowels for bracing $18
http://www.homedepot.com/p/Unbranded-1-2-in-x-1-2-in-Poplar-Square-Dowel-12-3HWSQED/202287696
4"x24" ABS for port $11
http://www.homedepot.com/p/VPC-4-in-x-2-ft-Plastic-ABS-Pipe-1204/202300521
$339 for 115db F3 23hz
