Ok, im making my own DIY wall mount for my Optoma HD70 , used 2 12x10 shelf brackets to hold to wal and a 13"x13" piece of 1/2" MDF as the shelf, painted it white so it matches wall and projector.
Now to the question - I need to drill 3 holes in the wood to stick the M3 Bolts through to mount to the projector - How would you go about marking the holes on the wood?
