Nice work, I appreciate the subjective comments song by song the most.
I think we all appreciate an honest capture and examination of the data, along with subjective listening, above all else. Great job.I know this may not be a glowing review that some expected to see but with as much time as I have spent measuring drivers for the DIY community over the last 10 years, hopefully you all know that I'm only providing my reviews as a means to help.
Does this mean you think it will sound decent once calibrated, say with something like Audyssey XT32 (and when crossed at 80 and paired with appropriate subs)While the on-axis response is not linear, the off-axis response trends very well with the on-axis and the directivity indeces are quite linear - outside of a couple areas. This means that this speaker should do quite well once equalized to flat (or, at least, more linear).
Any chance you have measurements with the v2 components?I actually grabbed my box and threw the v1 components back in to double check the response.
If I can use the same cabs/tuning and the only difference is drivers and crossover, and if @jcmccorm doesn't mind, and if you'd be willing..I'll take some new ones and get them posted tomorrow. I need to throw a v2 crossover together and get the drivers swapped.
I tested the Klipsch Heresy IV late last year. Though, not with the Klippel NFS. I tested it using other means but the data matches my NFS results which I will be posting soon.Looking forward to more of these.
It’s hard to get a feel for the results without a few comparable speakers to judge them against. The JBL 708 looks amazing, but those are in a totally different price range.
Would be interesting to see the Behringer 15, or the Mackie c200, or whatever cheap Pro audio speaker is the popular option at the time.
That's a great idea.If I can use the same cabs and the only difference is drivers and crossover, and if @jcmccorm doesn't mind, and if you'd be willing..
If you can send the updated parts to me, I can swap them out and test and we can have full data for the v2 speaker.
If that is a no go, then if someone wants to send me their v2 I will test it. But sending a big speaker like that isn't going to be cheap.
I agree, that would be fantastic!That's a great idea.
I think that is easily doable.If I can use the same cabs/tuning and the only difference is drivers and crossover, and if @jcmccorm doesn't mind, and if you'd be willing..
Sweet! When you're ready, shoot me a PM and I'll give you my shipping address.I think that is easily doable.
