Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
Hope someone can help.
My nephew updated the firmware on my Panny BD-55 to 2.0 from 1.1. The problem is now the unit does not play standard "normal" DVD's. It continues to try to read the discs and then it can't recognize. Plays Blue Ray disks fine, just won't read or play any other standard DVD and I've tried a bunch, even brand new I just opened.
Any ideas or if possible to revery firmware back? Thanks in advance for any help!!
· Premium Member
Your thread was already moved once to the owner's thread.
S~
· Premium Member
OP
Any and all questions and comments about this player belong in the owner's thread, which is where I moved the first thread you started. If a modertor moves or closes a thread, do not start another thread on the same topic.
1 - 3 of 3 Posts
Status
