I have had this unit a month and used it with basic/expanded cable sucessfully and just got Comast digital cable. The instructions say you can do plug-in auto programming, which I did to download all the new channels into the unit for recording. Well almost.
In order to record channels, like the HDTV channels in the #800+ range, what am I doing wrong? Do I have to re-wire the antenna/cable box connections? They did not download and I am unable to enter them manually, which you need to do to tell the DVR to record them.
Can I record channels 125 - 8##?
DVD Recorder Panny DMR-E55
Motorola cable box 6200
Toshiba 34HF83
Onkyo SR501
Comcast cable HDTV
Thank you
Toshiba 34HF83
Onkyo SR501
Comcast cable HDTV
Thank you
