Status
Not open for further replies.
1 - 5 of 5 Posts
I have noticed that every picture I see of bookshelf speakers has them on stands. If they need stands then they take up as much space as towers, and therefore loose some of their appeal to me.
What I wonder is if bookshelf speakers would actually sound good on a bookshelf. I think that is the only way that I would find them to be a benefit.
Any opinions?
You want to be careful especially if they are rear ported. You need to make sure that you give the port at least several inches to breathe. Stands are the ideal solution, but its very possible to get good results on a shelf also. Best thing is to try and experiment with it.
Most speakers, either bookshelf (despite the name) or floorstanding, sound best when placed alone away from surroundings. If you have to place them on a bookshelf, in addition to what Adam said, I would try to empty the shelf around the speakers as much as possible -- removing the books right next to the speakers, and immediately above and below.
[added in edit] Also, try to place them so that they are approximately at the level of the listener's head.
If you're using them in conjunction with a sub and have plugged the ports is the bookshelf location less of an issue (assuming you take sushi's advice and keep them at head height and away from books, etc)?
Premium Member
Any opinions?
These sound good on a bookshelf:
http://www.nhthifi.com/home_productI...p?ProductID=40
1 - 5 of 5 Posts
Status
