I'm planning on upgrading my AMD Athlon 64 X2 3800+ Manchester 2.0GHz cpu and BIOSTAR TForce6100-939 NVIDIA GeForce 6100 Micro ATX AMD Motherboard.
I'm currently thinking of going with the following:
Intel Core 2 Duo E4400 cpu
Foxconn G9657MA-8EKRS2H motherboard
(my HTPC case requires a mATX mainboard)
Can someone confirm I have the following calculated correctly?
* set FSB to 266MHz
* new CPU speed of 2.66GHz
* new DRAM speeds of DDR2-533/667/800/1066 (multipliers 1/1.25/1.5/2 respectively).
Anyone running an E4400 at 2.66GHz? With a Zalman CNPS7000B-CU heatsink? I currently have this heatsink and will need to buy the ZM-CS1 adapter to have it work on the new motherboard.
Finally, if this is a workable setup, I'd appreciate knowing what RAM you're using to achieve this...
My only other components are a nvidia video card (currently 7800GT but going ot move to 8500/8600 series card), Prodigy 7.1 LT, an ide dvdrw and a sata 160gb hd.
* set FSB to 266MHz
