I have three wireless routers but two are configured as switches. My main router is located right next to my cable modem. I then have a wireless router out in my theater room (200ft away in terms of cable length) that is connected to the main router via Cat 5e and is configured to act as a switch. I also have a wireless router in the upstairs corner of my house (100ft away in terms of cable length) that is connected to the main router via Cat 5e and is configured to act as a switch as well. The main router and two wireless routers/switches are all 100Mbps. None of them are Gigabit (1000Mbps) capable.
The computer that would hold all of my movies would be connected to the wireless router/switch in the upstairs corner of the house and the Dune HD Player would be connected to the wireless router/switch in the theater room, so they would be separated by two switches, one actual router, and 300ft of Cat 5e cable. Will I need to upgrade the main router and the two subsequent routers acting as switches to ones that are 10/100/1000Mbps capable in order to ensure proper streaming to the Dune player? Or will 100Mbps be fine even when others in the house are using the Internet (whether it be through wireless or wired connection)?
