Originally Posted by
hometheaterguy /forum/post/14385911
Darkhunter, ( I am not at all worried if I waste money, I just want it right). This is the system:
Alpine DA-X001 digital media iPOD controller
Audio Control DQL-8 competition 1/3 octave EQ (trunk mounted digital processor beast).I felt graphic is the best way to do the bulk of any tuning. I will have Sound Werks reserve parametric EQ tuning for the "laser surgery" I might need for troublesome freqs. If I don't need them, I won't use them. This beast of a digital processor has 30 bands of graphic EQ for the front, 19 for the rear, 13 for the sub, and 2 bands of parametric EQ per channel so it should be great and the EQT is out.
Rockford Fosgate T8004 Power Series high pass amp for the high end with 1/0 gauge power and ground connectors and an ANL fused at the amp. This HP amp will be run 2-channel bridged stereo mode into 4-OHMS @ 200W X 2. RF suggest that a "capacitor is recommended", of course, more money, LOL.
Rockford Fosgate T2001bd low pass amp mono amp @ 1500W X1 into 3 OHMS. It also has 1/0 gauge power and ground connectors with ANL fusing at the amp. I will have a 200AMP circuit breaker at the starter and audio system battery as well. Again Rockford throws in that "a high output alternator and large cap are recommended." I do not know the exact current demands for each of these amps. I think they come with 100A fuses.
Highs: Dynaudio System 362 (Esotec drivers, a 3-way setup). Soft dome mids in the dash, tweets and 8's in custom kick panel pods.
Sub: A single JL 13", the CLS113RG-W7, (Pro Wedge sealed JL made enclosure), up front in a custom center console enclosure.
The goals with this system are:
Sound quality: (competition type sound, loud, but not harsh, not bright, not too much).
I want just one solid, clean sounding sub, up front. (Tight, articulate bass, just not space shuttle sounding).
Tons of juice to the amps
7 speakers, HP/LP, (bi-amped)
No rear fill with no car theater crap.
All this thrown in an white 96 OJ Bronco and it is basically the Audio Controls 2-channel system called: "Great Sound You Can See" -which has thunderous bass and stunning clarity are characteristic of a 3-way system with an Epic-160 and DQX. The DDC and Epic-160 put the control at the touch of your fingers, and the rumble deep in your gut. Plus, the SPL display on the Epic-160. The DDC is a remote-mountable control that connects to AudioControl digital processors via a 20' cable. This allows a user to control all functions of their AudioControl processor from another location either inside or outside the vehicle. It also comes with the DR-1 which is a remote control that controls the functions of the DDC via IR (infrared). It will be IASCA worthy, but for personal use.
As for the cap being either subjective, or really doing anything for systems Steve of RTTI believes capacitors do help keep the voltage stable, the only time they are not beneficial is when you are really exceeding the amperage of the alternator. He recommends picking up the biggest capacitor I can get your hands on, and said you can never have too much. Others say the rule of thumb is at least a 1 farad cap per 1000 watts, but ultimately the more capacitance you have the better off you will be.
Have you heard of rumblings of a cap like the "Power Cap" from HO I am referring to? Unfortunately I have not had any personal experiences with this beast. If the specifications HO (
www.highoutputalternators.com ) provided are correct then it would definitely be a huge help. I am sure AVS has had many threads on the usefulness, or waste of using caps.
