Not really in the cards at the moment as something comparable to my S920w would be out of my budget currently. The Denon I have is rated for 90w which should be fine since I don't ever listen much over 75db according to the spl app on my phone. Before I rerun Audyssey and start futzing with the app though I was going to try turning it off completely and seeing if that does anything for me.Enchy, I'd try a new AVR (maybe get away from Audyssey) before going down other roads. Up the watts, too.
Good luck.
I have the RP-500C matched with FL/FR RP-600M and I'm quite pleased with the sound coming from this 3.0 system. For the RSL floor standing loudspeakers mentioned at the start of this tread, the RP-600C likely would suffice. I personally would prefer the RP-600C over the RP-450C.Lots of solid 2 way options out there, very reasonably priced.
Other centers worth considering, available at Best Buy and Crutchfield for easy returns:
- HTD Level 3 (free return shipping)
- Ascend 340SE
- Hsu HC-1
- Hsu CCB-8 (concentric design = zero lobing)
- JBL Stage 125 (avoid the Stage 135)
More upmarket, mainly if under severe WAF pressure or size limitations:
- Klipsch RP-500C, 600C
- Martin Logan centers
* Ascend Duo LCR
Yes, shutting down and reset, disconnect and reconnect everything. Worth a try.Not really in the cards at the moment as something comparable to my S920w would be out of my budget currently. The Denon I have is rated for 90w which should be fine since I don't ever listen much over 75db according to the spl app on my phone. Before I rerun Audyssey and start futzing with the app though I was going to try turning it off completely and seeing if that does anything for me.
I originally wanted to do a bookshelf speaker as my center (was on the hunt for a RSL bookshelf from the same era) but I got a different TV that mounts at a different height and now I don't have the clearance for a bookshelf.I have the RP-500C matched with FL/FR RP-600M and I'm quite pleased with the sound coming from this 3.0 system. For the RSL floor standing loudspeakers mentioned at the start of this tread, the RP-600C likely would suffice. I personally would prefer the RP-600C over the RP-450C.
On another system, my best sounding center speaker isn't actually a center speaker but a bookshelf speakers. One of my JBL paired bookshelf speakers went bad so I'm using the remaining vintage JBL J520M as a center speaker in a 5.1.2 system. It was a happy day to know that these old JBL speakers of mine could still be a useful speaker!
you are on the right track here (IMHO) after putting my Infinity in, I am sold on 3 way designs. you have a good list of suspects. While it is out of your target budget, the Infinity RC263 C is still worth it at list price (499)I'd considered the HC1 but from other research I've done it seems like a 3-way is going to be a large improvement over a 2-way MTM design, so I was mainly targeting that kind of speaker in my hunt (aside from the CG25).
Partly, for my home as the width of the 450C really would cause some issues in placement. But also, I like the larger woofers on the 600C than what is found on the 450C. Although, looking at the specs both speakers have the same frequency response 58 to 25K Hz so either should be fine. I did notice though that the 450C was on sale which would make them currently a better buy than the 600C...so don't let my preferences prevent you from doing what's best for you.I originally wanted to do a bookshelf speaker as my center (was on the hunt for a RSL bookshelf from the same era) but I got a different TV that mounts at a different height and now I don't have the clearance for a bookshelf.
Out of curiosity why would you go with the 2-way RP-500C or 600C over the 450C?
Disabled all Audyssey settings except for level adjustments, I'll give this a shot tonight and tomorrow and see if I get any improvement.Yes, shutting down and reset, disconnect and reconnect everything. Worth a try.
Good luck.
Ahh okay. Wasn't sure if there was some larger functional difference between the two that I was missing. I think I can accommodate the RP-450C's width with some re-arranging...Partly, for my home as the width of the 450C really would cause some issues in placement. But also, I like the larger woofers on the 600C than what is found on the 450C. Although, looking at the specs both speakers have the same frequency response 58 to 25K Hz so either should be fine. I did notice though that the 450C was on sale which would make them currently a better buy than the 600C...so don't let my preferences prevent you from doing what's best for you.
I’m started to be skeptical about the “phantom center” agenda - I have the regular unmodified C22 with FS52 as L/R, and people have told me repeatedly said that no center is better than the pioneer center, and I gotta say I disagree... both when upmixing a stereo source with Dolby Pro Logic II or listening to a 5.1 soundtrack and going into receiver settings and turning off the center speaker, I think the center improves things. Stereo is fine, but adding the center means you don’t have to sit dead middle and the mains sound clearer when they’re just playing effects/music on multichannel sources.Before you add a center try stereo
More speakers = more of a sonic mess in 90%+ of homes
In theory yea 5.1 is great and we'd all benefit from a properly calibrated system. So much immersion
In reality 5.1 sorta sucks and stereo will get the vast majority of people better SQ
As long as the set up of your system is rational and your space is good sure.I’m started to be skeptical about the “phantom center” agenda - I have the regular unmodified C22 with FS52 as L/R, and people have told me repeatedly said that no center is better than the pioneer center, and I gotta say I disagree... both when upmixing a stereo source with Dolby Pro Logic II or listening to a 5.1 soundtrack and going into receiver settings and turning off the center speaker, I think the center improves things. Stereo is fine, but adding the center means you don’t have to sit dead middle and the mains sound clearer when they’re just playing effects/music on multichannel sources.
I only gave it 30 minutes, but disabling Audyssey’s EQ made it distinctly worse. Was worth a shot though.Yes, shutting down and reset, disconnect and reconnect everything. Worth a try.
Good luck.
rubber doorstops, or if you want a neater look: angled speaker padsSide question. Looks like both of these are rectangles, as opposed to the curved cabinet on the modified C22 that I have. How do people normally tilt their center channel up to make it ear height?
Yeah I plan on doing about a week each. Break in time should be pretty easy to attain since the TV is used by my kid like 4-6 hours a day watching Disney movies.Take your time with the comparison. When I first got the Elac Debut 2.0's they were very harsh on badly recorded TV shows (old Mash, etc). To the point that I was very close to returning them and then, after maybe 40 hrs of use, something changed and the listening got smoother. At least that was my experience with speaker "break-in", whether it really exists or not.
