Status
Not open for further replies.
1 - 2 of 2 Posts
Hello !
Just bough a basic 720P 16:9 LCD TV to use as my computer monitor & TV.
I have a digital cable receiver right now.
We DO NOT have ANY HDTV channels in our area.
Question is.
Do I need an HD Receiver ?
Will I get a better image quality from those regular digital channels with a HD receiver ?
Will the regular receiver display SD signal properly in a 16:9 format ?
Thanx a lot !
Do I need an HD Receiver ? No, if no HD is available via cable or OTA, there's no point
Will I get a better image quality from those regular digital channels with a HD receiver ? Most likely not, your display should convert any input it gets to it's 720p native resolution internally.
Will the regular receiver display SD signal properly in a 16:9 format ? - No, SD is 4:3, see if your TV has any stretch or zoom modes to make it fit.
1 - 2 of 2 Posts
Status
