Status
Not open for further replies.
1 - 7 of 7 Posts
I have a standard RCA round dish installation mounted to the roof. Is the oval dish mounting arm, etc. compatible with the round dish or will I need to re-mount the entire system?
They were with mine. I started with a terk round and upgraded to a sony oval. You will want to make sure it is plumb, the oval dishes are much more sensitive to this.
Brian
Yes almost Identical, I upgraded to the oval dish and used my original post from my first system. I didn't have to move it and caught both satellites from were the original one was located. Some simple adjustments (Took a few hours and it was my fault.)
Worked like a charm!
Graphics
STOP DVI/HDCP AND DFAST boycott JVC
Same mast on the Dish Network dishes.
Mark A. Torre
NEC XG-8"CRT PJ, HTPC, HDTV and loving it! The Torre Home Theater
The only problem might come up when you have to swing the dish a little further West to center the two sat. locations. If your round dish is nearing contact with the roof on its right side you might have a problem. My mount was on an east wall and the eliptical dish couldn't swing far enough right/west until I built a bigger offset between the wall and the post.
1 - 7 of 7 Posts
Status
