I eagerly purchased a HTD Level 3 center channel with these specs...
Max. Power Handling: 150 watts
Frequency Response: 45 Hz - 40 kHz
Impedance: 8 ohms
Sensitivity: 89dB
Voice Coil: 1.5"
Dual 6.5" woofers with a Ribbon Tweeter
Shielded Magnet: woofer: 14 + 11 OZ; tweeter: .7 OZ neodymium
Crossover: 3rd order at 2500Hz
Dimensions (HxWxD): 8.3" x 23.25" x 9.5"
Weight (per piece): 26 lbs
I am replacing a Jamo Center 100 that has these specs...
System Type 2-way closed shielded
Woofer (mm/in) 2 x 95 / 3¾
Tweeter (mm/in) 25 / 1
Power (W, long/short term) 70 / 100
Sensitivity (dB, 2.8V/1m) 88
Frequency Range (Hz) 100 - 20,000
Impedence (Ohm) 8
Weight (kg/lb) 1.7 / 3.7
Product dimensions (mm/in, HxWxD) 112 x 300 x 93 / 4.4 x 11.8 x 3.7
Overall dimensions (mm/in, HxWxD) 112 × 300 × 112 / 4.4 × 11.8 × 4.4
I am using a Sony STR-DG710 to push these. I most definatly will be replacing this AVR in the future but finances could not afford me to purchase everything I wanted. I do have a solid plan though. At any rate, I am finding that I have to turn the volume up on the new much larger HTD center than the old one. I would think that since the HTD has a higher sensitivity it should be the opposite. Correct?
Impedance: 8 ohms
Sensitivity: 89dB
Voice Coil: 1.5"
Impedence (Ohm) 8
