#2
CRT TVs don't have a native resolution, but they have a sweet spot. If you have a hi-res tube and feed a 480p signal you end up with visible scanlines (black lines), so higher resolutions get your better "fill rates".
LCDs, Plasma, OLED all have one native resolution and if you feed anything else, the display will upscale the signal to the panel's native resolution.
If you set your Roku to 720p, then the Roku scales to 720p, no matter if the file is 360p, 480p or anything else. A CRT won't scale afterwards, but just display the 720p output from the Roku. A LCD, plasma or OLED will further upscale the image to (usually) 1080p.
Many multisync CRTs, like "newer" HDTV sets, cannot display 480i any longer. 480i is often processed, deinterlaced or framedoubled and displayed as 480p internally.
DVDs themselves can be 480p24 (since around 2002), but the player then performs a telecine and outputs them as 480i60 instead.
If you feed 480i to a LCD the signal gets first deinterlaced to 480p and then upscaled to 1080p (or whatever the panel's native resolution might be).
