Status
Not open for further replies.
1 - 7 of 7 Posts
I have am probably going to buy a RCA DTC-100 because the price at my local BB is just too good. But I am getting a AE100 and will buy a transcoder for my prog DVD. This means I will have 2 VGA sources and one input on the proj. Now does the AA transcoder have the ability to input a VGA too or is it just the output? and if not like I'm suspecting, do the VGA switcher have enough frequency to do this?
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=2029918265
Quick answers would be really helpful because I dont know how long the DTC-100 will last... and hte ebay auction is almost over too.
i use a passive a/v switch for my component devices. using a passive VGA switch should be similar. i've always argued that passive devices are adequate even for HD signals. i say give it a try.
Cheap, manual, passive VGA swicher do not have the bandwidth for HDTV which requires 350 Mhz or higher. These are intended for 800X600 or less resolution. Of course for $10-20 at local computer store you can give it a try. I really think it will ghost/ring on you. At minimum go with a Belkin Omniview 2->1 or 4->1 active switcher for $45-55 at www.harmonycomputers.com . Even better go with Kramer VP-211 ($200) from www.copperbox.com .
Premium Member
I went with an Extron switcher. After trying the inexpensive passive switcher....as stated there were a few problems like ghosting etc. Once I went to the extron.....bam, terrific picture, as I would have expected. The automated switcher allowed for ease of operation=one input on the projector and no manual switching. AND, since I was using one TV input, the cost for an ISF calibration was less (not having to calibrate more than one input in the Mit's case).
Ron
I am also using a cheap $25 AV switcher from RS between my DVD/STB and Marantz projector. However I see a slight but noticeable degradation of the image. Nothing huge but we notice it every time.
Unfortunately we really need a matrix switcher so we can switch both for the source and between projector and TV on the receiving end. Haven't found a good switcher for that yet except the $7,000 unit from Extron.
1 - 7 of 7 Posts
Status
