Before I describe my situation, I want everyone to be aware that I am a cable noob and know absolutely nothing about the technicalities behind cable.
I'm having problems with my cable connection. Basically, what I want to do is split the connection three times (one for TV, one for Analog TV on a ATI 650 PCI tuner, and one for digital on an ATI 650 PCI). The problem is, once I install my splitter (a dynex DX-AV101) I no longer get the ClearQAM channels and my signal is heavily degraded.
If I plug in the original cable in to my ATI 650 PCI tuner then it looks fine and the signal comes in ok, same for analog (it can't reach over to my TV, which is part of the problem).
So besides the Dynex splitter, here is what I'm using:
25 foot coax (Philips) bought from Wal-Mart (non-gold plated)
12 foot coax bought from MonoPrice (gold plated)
12 foot coax (Philips) bought from Wal-Mart (non-gold plated)
The original cable coming into my room is probably about 12 feet.
Would adding a signal booster help me keep my ClearQAM channels and the semi-full analog signal? If so, if I bought one from Radioshack (doesn't have to be from here, just an example), could I plug that in and then use my splitter to split the signal or would that negate the purpose of the signal booster?
Oh and before anyone says "ask your cable company for one". They won't give me one because I'm getting my signal (just not powerful enough to split).
