1 - 3 of 3 Posts
Discussion Starter #1
I have the front panel and components, but didn't order the flat pack. Wondering if anyone in this forum got drawings for the whole cabinet?
The cabinet was 10.25" wide, 28" tall, and 12" deep counting the front baffle.
There were three braces spaced equally within the cabinet, but that was overkill and not really needed. You could make two window pane braces that look just like the Fusion-8 center channel and put one one each side of the waveguide and it would be plenty strong enough. If they were ever done again, that's how the flat packs would be.
Discussion Starter #3
Thanks for the drawing Erich, always easier to build when there is a drawing.
Cheers
Manusha
1 - 3 of 3 Posts
