Originally posted by Phil Olson If anyone knows a trick of how to get the DVI out to work as default, let me know. |
Originally posted by Phil Olson Have you tried to get it to work just with the DVI using the VGA dongle? I couldn't get that to work at all. If you say that turning off plug and play will do the trick, I'll give it a try. If that doesn't do it, it's going back. (Phil |
What happened to the HDTV decoder that was supposed to have been implemented on the All-in-Wonder Radeon 8500DV? It is clearly visible in the pre-release diagrams but not mentioned as a feature in their release notes. |
The decoder is there, it is simply not used. The demand for it is simply not great enough. There is a need for a front end for the decoder before it can be used. |
