Status
Not open for further replies.
1 - 5 of 5 Posts
95%. Sometimes when I get errors, re-transferring the file from DVA fixes most of those problems. Not sure why, but that's the way it is for me.
If flawless means that it cuts at the edit points that the replay detected, then yes. I've never had any probs with Revue.
Originally posted by icecow
Does anyone have flawless success using reVue to edit?
cow
Depends on your definition. the RTV does not always catch the commercial cutpoints... (i'm watching an episode of 'king of queens' that RTV says there are no commercials in ! >lol
I just ran a cat5 cable across my attic so I could use rtvtools with ReVue and edit the commercials. However, the edit points aren't always where they should be. I got my system to where Gspot reports mpeg2 splitter but the edit points haven't changed. I have WMP9 but I have DX8.1. Any suggestions? Bigjohns, when you fixed your problem did it change the edit points right away? icecow, have you fixed your problem?
1 - 5 of 5 Posts
Status
