Status
Not open for further replies.
1 - 1 of 1 Posts
Hi All,
First of all I have the mits hd5. Our local pbs station just added a high def station (yeah). The first day it went live I entered the channel into the receiver and the station came in fine. The quide for the station stated that the it was showing "regular schedule". No problem just figured they didn't get their schedule to whoever. The next day I turned it on and the guide gave me a true listing, I thought great until I turned to the station and the high defininition station wasn't there. it was showing the regular pbs station, not the high def. I had this happen before with some other stations and the only way i could fix it was to eliminate the guide for the local stations and then the stations would show up. This was "fixed" at the last upgrade but the pbs station came on line after that.
any thoughts? I checked in the menu where you can scan the channels and it says that the station is loaded correctly.
thanks
John
1 - 1 of 1 Posts
Status
