Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally Posted by fj6474 /forum/post/18179877
at listening position?
Originally Posted by maxmercy /forum/post/18180043
THT above 25Hz can do it pretty easily...
Originally Posted by fj6474 /forum/post/18180066
I cant get my THT above 103 @ LP, however my LLTs max my meter though.
Originally Posted by maxmercy /forum/post/18180184
Strange...have you measured freq response at your LP? What makes the THT stop at 103? Amp limitation? Distortion? Above 25Hz, THT is a monster....below 20Hz, distortion can become a serious problem if you boost too much....
JSS
Originally Posted by reecew /forum/post/18181059
Sure you have a THT not a table tuba lol? I can max out my spl meter down to 16hz nearfield and get to around 119-120db at my lp as well.![]()
Originally Posted by fj6474 /forum/post/18181772
No sir, I am positive it is a THT. I bought into all the hype and it just doesnt touch my LLts in my HT room. The THT does better in my testing room with lower power?
Originally Posted by fj6474 /forum/post/18181758
I wish I new, I will be playing with it later on in the day. All I know is that it does alot better in a different testing room on a smaller amp then in my HT room, a drastic difference with lower power.
Originally Posted by A9X-308 /forum/post/18183256
Not having the drawings to model it out, perhaps Fc is around 25Hz. Under Fc, you have a large driver in a small sealed box as there is no more horn loading. My LABsubs were the same from about 30Hz.
