Status
Not open for further replies.
1 - 8 of 8 Posts
Yep.
Dan
It's been activated for months. Menu, 6, 1, 4 to turn it on.
Dan
Mitsubishi 55805
Dish 6000
DirecTv/Mitsu SR-HD400
Evu 6000
Question for DP1, I noticed you have the Mitsubishi HDSR400 in addtion to the 6000. Does the Mitsubishi give you the option to stretch or zoom up-converted material to fill a 16:9 display like the 6000 does? I am not talking about 480i/4:3 SD sources but upconverted 480i to 1080i like we get on HBOHD that are shown in 4:3 aspect ratio. The sony HD100 box for example will stretch up-converted material to fill the screen only after if has down-converted to 480i. Is the scheme different on the Mitsubishi?
Also note that the 6000 caller ID function is conveniently disabled during timer recording so that your recording is not disturbed.
--Gerald C
STOP DVI/HDCP!
1 - 8 of 8 Posts
Status
