Hi i asked the makers of my LCD TV, Panasonic certain questions but it seemed they think it is too technical and i have not heard from them for a while so i wish to clarify certain questions i have
1. Does every LCD TV contain a basic/crude DAC?
2. Does it matter if i connect my cable TV box to the TV via analog/component or HDMI? If there is a DAC in the TV then it would not be activated if one uses a non digital connection right?
3. Can i route video via HDMI to the LCD TV and the audio out from the cable TV box to an external DAC for example? The cable box has a digital optical out
4. If i do not connect anything into the "audio monitor out" at the rear of the TV how should i select sound options for my TV i.e digital, auto or analog? I am thinking of a cheap DAC in the Fiio D3 Or should these settings be on the cable tv box? By the way my cheapo TV (Panasonic TX-32LE8M) only has 2 HDMI ports and the rest are RCA/component and no optical/coax
http://www.fiio.com.cn/product/index...&MenuID=020301
5. I am thinking of populating those 2 HDMI ports with
a. cable TV box (already connected via HDMI1)
b. Blu Ray player into HDMI2 (yet to purchase)
do Blu Ray players these days have coax out? Could i use the Fiio D3 input selector (optical/coax) to toggle between items a and b to an external audio system bypassing TV internal speakers? Do Blu Ray players have a menu to select what mode to route audio out?
6. I have not set up external speakers yet but this would be strictly 2.0 floor standers or 2.1 bookshelf + sub so no need for 5.1/7.1 support/configurations
Thanks in advance to anyone who could help me out
edit : how the rear of the TV looks like
