1 - 3 of 3 Posts
Can anyone give the straight scoop about whether the Mitsubishi HC500BL LCD display device does or doesn't do 1080p @ 24 frames per second rate?
I don't see it listed on the data contained in the product brochure handed out by the Mitsubishi folks at the '07 CES...and unfortunately I flat out forgot to ask such important question when I chatted with them then (too busy talking about current NFL playoffs instead!), so any help with this will be greatly appreciated...
-THTS
I set my Nvidia card to advanced timing for 1920x1080x23.97P and it works fine. The projector info page actually shows 23.98, but hey it works. Haven't tested yet to see if judder is elminated but I will soon hopefully. This is using PC-DVI to PJ-HDMI.
1 - 3 of 3 Posts
