Status
Not open for further replies.
1 - 4 of 4 Posts
Hello
I am looking into buying a Panasonic DMREH50S and was wondering if it will work with my Bell Expressvu HD 6100.
This is a $700 investment and I was told differeent story.
One of them was at BestBuy in Canada the guy told me that the 6100 wouldl know that a recorder is hookup to it and would not let the signal go trough.
I found this very difficult to believe
Called Panasonic Canada got a service rep ( mostly a secretary ) asked th esame question and got yes yes it will work and Merry Xmas and klonk.
So I really need to know if any of you have of of these similar unit or other brand hookup to your Bell Expressvu HD model 6100
Certainly dont want to spend 700$ and found out later it will not work.
If the answer is forget about it it qill be fine I will then turn around and buy a HD DVD player.
Appreciate your input
Discussion Starter · #3 ·
Tks for the info
But maybe in need to be more clear hear.
If I am looking at a Channel would it be HD or SD this could be a MPIX, First Choice etc,
Will this set up be OK will the unit record the show on the DVD
I dont think their is copy protectioon on th esignal coming of the 6100 box
Anyway I am a newbie here and need your input
tks
1 - 4 of 4 Posts
Status
